Using the Valencia template, I would like to add a background image to an empty module, in position bottom-3.
I've prepared a 1600x960 image and assigned as the background image for that row. I've also increased the top/bottom padding to make a larger view.
However, when in full screen, the image wraps at the slides. Also around the size of a tablet in portrait, it will wrap vertically.
On the same page, I've used the same sized image in position top-2 with no problems, but the other difference is that module contains text.
- Are there any tricks / tips for setting up an empty module to display a background image? For some reason do background images in the bottom positions have to be wider?
I've attached an image to illustrate.
Many thanks,
Marc
