1. [email protected]
  3. Tuesday, 18 June 2024
I use the Template J51_Ensley on the webside http://www.schoenheitswerk-sarina.ch
Under the menu item "Angebot", there is a submenu item. How can I change the background color of that submenu item from white to #94162F?
Best regard,
Basil
  1. http://www.schoenheitswerk-sarina.ch
Go to:
template style|General|menus| and change the dropdown background color
Hi FrancW,
I work with the Joomla5 CMS and when I go to Templates, I see the screen in the appendix. When I worked with Joomla3, I could do some setting with dropdown menu etc. But since I work with Joomla5, I just see the file structure und I assume, I must change it in a css-file.
Can you tell me in which file I have to change it? The mistake is just when I visit my webpage over a laptop. When I visit my webpage over a smartphone, the background is red.
Best regards,
Basil
You don't need to adapt the template itself, just the template style.
log in Joomla5, chooses system then Site Template Styles. Choose J51_Ensley default. Go to tab general, then menus and change color in Dropdown background color
Hi FrancW,
Thanks a lot for your answer and the clarification. It worked :D
Best regards,
Basil
