1. ahuppert
  3. Friday, 18 October 2013
I am using the AWAKE template and have added a bit of require code to the header of the site. It appears as if it works just fine in every browser EXCEPT Firefox. I'm not sure what to do to correct it. The script adds a authorized dealer logo to the top of the entire site (as required by the manufacturer):
<script src="//http://www.amsoil.com/services/webcontent.ashx?type=badge&;zo=#"></script>
In Firefox, it pushes the entire site off to the RIGHT. Any ideas as to what is causing this, or how to fix it?
After digging through Firebug, I decided to go to the CSS to try and resolve this issue. It appeared to me that the #WRAPPER was moving over to the right at the will of the added <SCRIPT>.
I seem to have corrected the problem by changing:
#wrapper {width: 958px; height:auto; display:table; text-align:left; margin:0 auto; }
to:
#wrapper {width: 958px; height:auto; display:table; text-align:left; margin:0 auto; clear:both; }
I added "clear:both" to reset the float property. I'm not sure if this is the "correct" fix, but it looks like it is working. If anyone can confirm for me whether or not this is the correct solution, I would greatly appreciate it!
Thank you for the update.
Yes clearing the div would be a suitable solution as this simply clears any floating that may have been added by your plugin previous to the wrapper div.
