Hello, I would like to buy the Avenue-template, but would like to know if it is possible to remove the sun-burst? I see a dropbox URL in another post, but how/where do I incorporate that?
Thank you.
The header.jpg mentioned in other posts (http://www.joomla51.com/forum/support/commercial-templates/j51-avenue) can be used to replace the original sun-burst header image. You will find this fill located at ../templates/j51_avenue/images/style1/header.jpg from the root of your Joomla installation.
