1. ziggy
  4. Monday, 21 January 2013
Hi - I have set up my autson slideshow in the evolution template (using joomla 3). Uploaded the images, applied the arrows for navigation. The slideshow shows the first image, but it doesn't 'slide' - in other words, it doesn't show any other of the images, even when I click the navigation arrows.
I am viewing in IE9 and on my local machine running WAMP.
Any idea's?
thx
robin
Hi Robin
It is difficult to say for sure without been able to access your site. Ensure that jQuery is enabled via the slideshows parameters. Also ensure no other extension is conflicting with the slideshow, try temporarily disabling any 3rd party extensions and plugins and see if this amends the issue.
That did it... I had to turn on the jQuery in the params. Thanks so much.
Just a thought... you should add this little tidbit to your PDF on install instructions.
Again, thank you for your quick, decisive, response. I will definately recommend your products in the future.
robin
