Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. brynseion
  3. Friday, 22 June 2012
First time using Joomla51 and trying to set up atlas template on xampp. Quite a few error / warning messages have come up:
ON FIRST LOADING TEMPLATE:
Strict Standards: Non-static method JPlugin::loadLanguage() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\church\templates\j51_atlas\index.php on line 9
Notice: Undefined property: JDocumentHTML::$_name in C:\xampp\htdocs\church\libraries\joomla\plugin\plugin.php on line 105
Notice: Undefined property: JDocumentHTML::$_name in C:\xampp\htdocs\church\libraries\joomla\plugin\plugin.php on line 107
Notice: Undefined variable: siteName in C:\xampp\htdocs\church\templates\j51_atlas\index.php on line 96
ON LOADING NIVO-SZAKI SLIDER:
Notice: Undefined variable: folders in C:\xampp\htdocs\church\modules\mod_nivoslider\tmpl\default.php on line 15
Strict Standards: Only variables should be assigned by reference in C:\xampp\htdocs\church\modules\mod_nivoslider\helper.php on line 19
I have Joomla 2.5.6 and although Atlas is supposedly compatible with 2.5 there was no zip file for it so used the latest provided. Can anyone please help me get Atlas set up properly? Appreciate your help - thanks.
Hi brynseion
Should amend itself once you upload to a host but in the meantime may I suggest replacing the following in the head of your templates index.php (../templates/j51_atlas/index.php)..
<?php
|| # Copyright (C) 2010 Joomla51. All Rights Reserved. ||
|| # license - PHP files are licensed under GNU/GPL V2 ||
|| # license - CSS - JS - IMAGE files are Copyrighted material ||
|| # Website: http://www.joomla51.com ||
defined('_JEXEC') or die;
JPlugin::loadLanguage( 'tpl_SG1' );
JHTML::_('behavior.mootools');
define( 'Jmasterframework', dirname(__FILE__) );
require( Jmasterframework.DS."config.php");
$path = $this->baseurl.'/templates/'.$this->template;
$app = JFactory::getApplication();
$app->getCfg('sitename');
$sidecol_width = $this->params->get('sidecol_width');
$col_pos = $this->params->get('col_pos');
$templateparams = $app->getTemplate(true)->params;
Replace with....
<?php
$siteName = $this->params->get('siteName');
Thanks Ciaran. Worked a treat.
Can you work your magic on the notices which came up when I loaded the nivoslider too?
Many thanks.
PS - screenshot attached as per Sticky request. Thanks.
[attachment]screenshot-ceredigion-meth.png[/attachment]
For this issue while on your localhost may I suggest setting your Error Reporting to None or Simple (Site -> Global COnfiguration -> Server -> Error Reporting). If the issue is still present when you upload to your host I may ask you to set us up with temporary administration access so we can examine the issue further.
Thank you Ciaran. Sorted and will come back to you if issues still there when go online. Thanks very much for your help.
