Warning
JUser: :_load: Unable to load user with ID: 282
  1. pat02
  4. Thursday, 11 February 2016
The Template "Ashley" display the main navigation wrong in Safari.
Wrong: Safari:
Correct: Firefox:
It would be great if you would fix this, thank you very much.
Patrick
Hi Patrick
May I ask what version of Safari you are using? PC or Mac? The menu of our Ashley template uses the Flex CSS property which would not be supported on older browsers... http://www.w3schools.com/cssref/css3_pr_flex.asp
Hi Ciarán
I just updated MAC OS and Safari, now it's OK. :)
On Windows I had Safari 5 which is old. Removed it...
Thank you very much.
Patrick
Happy to help :)
Thank you for the update!
I have the same problem. Safari 5.1.7 on Windows. But there is no newer version of Safari for windows. Or I am wrong.
https://en.wikipedia.org/wiki/Safari_version_history
regards, Pascale
Hi Pascale
Safari for windows has been discontinued some time ago so would not support flex. We can set a width to your menu items depending on how many you have however this would break if you were to add/remove any items.
Dear Ciaran
Thanks for your answer. I will solve the issue with CSS.
best regards, Pascale
