I am using the Ashley template. I am using the j51 slideshow module with this template. I had it set up before that the slideshow went all the way to the edge of the template. On a new installation I can't seem to replicate this. Here is a link to the two sites so you can see what I mean. In the first link the slideshow goes to the edge and in the second link it stops short.
http://www.ourladyoflourdesrosbrien.ie/
http://www.ourladyoflourdesrosbrien.ie/joomla30/
Thanks,
Kevin Frehill
