Hi there,
Is it possible to have the background semi-transparent in Ashley so that the background shows through similar to the Clarity template?
I couldn't see an obvious setting.
Cheers,
Euan
			- euanmcginty
- Monday, 14 March 2016
				Hi Euan
To remove the background color of your side column modules try adding the following to the Custom CSS field of your templates parameters...
.backgrounds .sidecol_a, .backgrounds .sidecol_b, .sidecol_a, .sidecol_b {
} Ciarán
				Hi Ciarán,
I'm having a similar problem now with the left menu. The template is now live on http://www.oceanoptometry.ca and in the pages for "the Collections" for frame collections and exam collections the module in sidecol-a should be semi-transparent. The CSS has:
#container_main, #container_slideshow, #container_sidecol-a {
background-color: rgba(255, 255, 255, 0.8);
but the left menu is solid???
Sorry to bother you with this again
Thanks,
Euan
 Thanks,
Euan
				Hi Ciarán,
That sorted it - I perhaps had a typo previously. Now having fun playing with different degrees of transparency for different positions - too much choice!
Cheers,
Euan
Cheers,
Euan
				Hi Euan
The above CSS with #container_slideshow should have done the trick. Would you have a URL to this and I will examine it further?
				Thanks for this, Ciarán, almost perfect!  The issue I have is that I have thick white bands at either side of the Layer Slideshow component where they're not transparent.  I've tried adding:
#container_main, #container_header, #container_showcase {
but that didn't do it.
Is there a way to have these areas semi-transparent as well so that it looks seamless?
Cheers,
Euan
Cheers,
Euan
				Hi Euan
#container_main, #container_header {
} Ciarán
