Hi folks,
I have started to set up the Ashley template, and so far it is working nicely except for one small issue. When viewed on mobile, the text of a displayed article disappears off the right side of the screen, requiring scrolling. When I do scroll, the uncovered area is the background colour, which the text overlaps.
I have the template set up in the S-C-S configuration, using only the right sidebar (so effectively CS).
I've only got the site set up locally so far, though I could put it up somewhere for you to investigate if necessary. But I was wondering whether you could give me some pointers towards what I could check to spot the issue.
Regards,
Joal
