1. HighlandJ51
  4. Thursday, 27 July 2017
IE11 users have told us that they can't access the main menu on the site we built using the Ashley template - the only way they can navigate is through the footer menu.
We're a Mac operation and can't view the site in IE11 - can you take a look at it and see if you have the same issue?
Thanks,
Jeff Baruch
The Highland Group, LLC
  1. http://www.wcjcobgyn.com/
Hi Ciarán -
Thanks for the help - the problem seems to have been solved.
Jeff Baruch
Hi Jeff
There certainly appears to be an issue in IE11. This issue is unique to your Joomla installation as we are unable to replicate on the template demo. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
We resolved this issue by adding the following to the Custom CSS field of your templates parameters...
body {position: static !important;}
