1. rogimon
  3. Thursday, 15 September 2016
I am having a bit of a task getting this doe. See here I got the column in the position I want but then it pushes down the main content section to the bottom. If I reduce the width of the side column to 23%, the content goes back up to it's correct position. But then, the column will be too narrow.
The CSS I used is this. I added a margin to top and left and reduced the height to 95%
.sidecol_a, .sidecol_b, #content_full, #content_remainder, .content_background {
height: 95%;
margin-left: 35px;
margin-top: 20px;
position: relative;
Can it work the way I want it to?
Could I ask you to check the URL provided as it appears to be giving us a 404 error.
I just clicked the link and got through.
Thank you. Your site is now loading.
Could you detail for me what you are trying to achieve with your custom CSS? Page appears to load fine without it.
Sorry but it is not loading the way I want it. I have attached an image (img.jpg) which compares how the site is made to work without any custom css code and how it looks with the code I have edited. Notice the heading TOURS falls below the content in the side column.
The second image (mock up) is the way I want to display my site.
Presuming I understand you correctly and you wish your side column to start inline with your component content try adding the following to the Custom CSS field of your templates parameters...
.sidecol_a {
margin-top: 44px;
Thanks but that didn't work. Ended up creating a module class suffix which did the trick.
