1. kpomilla
  3. Tuesday, 26 July 2016
I'm using the Ashley template and I have header-1 and header-2 modules, that look perfect on a desktop. I've hidden the two modules for mobile devices; what I want is to utilize a second header-1 custom html module (a call now button) that only shows on mobile devices. How can I make this happen?
See the attached screen grabs (both full screen and mobile). Preferably, I'd like the call now button to appear at the top on the hornav...
Thanks in advance for your help.
Would you have a URL to an example of your modules?
http://thewebstoretest.com/basketcase/index.php
I have set the call now module to published for now...it shows on a computer, but doesn't show on mobile devices. I don't know how to distinguish between headers and make one visible on mobile devices and one not visible. Add to that, I don't want the call now button visible to desktop/laptop users.
Thanks for your help
You appear to have the following in your Custom CSS which will hide your header positions depending on the vertical height of the screen. I suspect this is why you cannot see the module on mobile devices due to the smaller screen height...
@media only screen and (max-height: 700px) {
/* Hide default hornav menu */
.header-1 {display:none !important;}
.header-2 {display:none !important;}
.newmodule {display:block;}
.visible-phone {
display: none !important;
To hide a particular element on a mobile device try adding the 'hidden-phone' class name to it.
I removed the section of css, then added the class hidden-phone to the header-1 module (text) and then I added the class visible-phone to the call now button but still no luck.
I am unable to see the class names in your website source. To add the class to the entire module you can use the 'Module Class Suffix' field (http://www.joomla51.com/tutorials/item/hide-a-joomla-module-on-mobile-devices).
Alternatively the class can be added to individual items like so...
<img class="hidden=phone" style="display: block; margin-left: auto; margin-right: auto;" alt="callnow" src="/basketcase/images/callnow.png">
