1. bcrawley
  3. Friday, 26 August 2016
How does one go about changing the background color of the footer menu and copy-right on the footer menu for the Ashley template? By default it's transparent so the footer menu doesn't stand out and I'm not seeing how to change it.
To set a background color for your footer area try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
#container_footermenu .wrapper960 {
background-color: #2a2a2a;
padding: 30px 0;
That worked! Thank you! One other question, the footer menu is bumped against the edge now that we have the background color and it looks weird. How can I off-set the footer menu so it can be moved over to the right slightly? See the attached screen shot. Thank you so much!
To amend try changing the suggest CSS to the following (edit to taste)...
padding: 30px 20px;
