1. twisterking
  3. Wednesday, 06 January 2016
Hi, I'm using the great artisan template on one of my websites. There is however a small issue when viewed on smaller screens. It sometimes happens that the screensize is not small enough so that it switches to mobile, and then parts of the menu disappear. Sometimes they even dissapear behind the lower dark border.
http://www.bvtilburg.nl/2016/probleem.jpg
The scrollbars on the right side of the screen only scroll the article-area, not the menu.
Best solution would be that the whole page scrolls when the menu gets longer, not just the article.
To allow you side column to scroll with the content try adding the following to the Custom CSS field of your templates parameters...
.sidebar_wrapper {
position: absolute;
That works but now the sidebar always scrolls with the page.
Isn't there a way to make this only happen if the height of the page is less than 800px (for example)? Then 99% of the visitors would get the normal view and the 1% with the smalle monitors get the scrolling version.
You could try placing the suggested CSS within a media query. Something like the following (edit to taste)...
@media only screen and (max-height: 800px) {
.sidebar_wrapper {
position: absolute;
Still not what I'm looking for. The problem is in the subitems from the menu. If you click on a menu-item which has subitems, the subitems from the last menu-item unfold, and on some smaller screens the bottom subitems disappear behind the lower border. This only happens if a menu has a lot of items/subitems.
What I'm looking for is that the sidebar gets larger (higher) with larger menus. Is there a way to set a custom sidebar height?
If have moved one of the menu-items to a higher position in the menu. This solves my problem for now, Thanks Ciarán for your help and your wonderful templates.
Luc
Hi Luc
Could I ask you to try using the following instead...
.sidebar_wrapper {
position: absolute;
height: auto;
#socialmedia, #copyright {
position: relative;
[img size=600]http://www.bvtilburg.nl/2016/probleem2.jpg[/img]
Not wat I was looking for, the problem still exists.
I just want the height of the sidebar to adjust to the number of menu- and submenuitems in the main menu, or have a sidebar with a minimum height. On larger screens the basic height is enough, but when the screen size gets smaller the sidebar gets smaller but the menu stays the same height. And then the bottom (sub)items get outside the wrapper.
I don't think that there's an easy solution for this problem, and as it will only affect a very small number of visitors I will just move the bottom menu-item to a higher position in the main menu.
Hi Luc
One possible alternative option would be to simply hide these items if the screen height is to small. To do so you can add the following to the Custom CSS field of your templates parameters...
display: none;
DID this topic ever get sorted? my issue is the same, In Smaller screens, longer drop menu items go off screen....
http://www.odellfurniture.com/
Hi Patrick
Fixed vertical menus will always be limited to the number of menu items which can be added to them. Would you like the mobile menu to be displayed if there is not enough vertical space to accommodate your menu?
Yes I would, Thank you Ciaran....How would I do that?
Or is it possible for the menu to just scroll with the page?
Hi Patrick
To amend try adding the following to the Custom CSS field of your templates parameters where 700px is the screen height to switch to the mobile menu (edit to taste)...
@media only screen and (max-height: 700px) {
/* Hide default hornav menu */
.hornav {display:none !important;}
/* Show mobile hornav menu */
.slicknav_menu {display:block;}
