1. Oliver Wilhelm
  3. Monday, 18 July 2016
Can I active menu points to assign a different color???
Now all have the menu entries the same color....
But I want the active menu item has a different color . Much layer already during hover with the mouse?
Thank You :-)
Hi Oliver
Presuming I understand you correctly try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
.hornav ul li.active a {
color: #888888;
Ciaran..thank You!!!
it is possible that the color has changed even when mouse over it?
AND:
is it possible to insert a Scoll Button same like the template Boutique?
Hi Oliver
To set the hover color of the active item you can also use the following....
.hornav ul li.active a:hover {
color: #888888;
Sorry to say there is no option for a scroll to button on our Artisan template.
