1. Pappy
  4. Thursday, 05 November 2015
How can I keep the sidebar and menu on a horizontal Ipad?
Try reducing the 'Template Width' option in your templates 'Layout Options' tab. Your template will automatically convert to the mobile menu when the screen is to small to fit your side column and content column.
If I reduce it to 720 the sidebar/menu will stay visible, but the text/content (right side) is running off the right side of the content area.
Also, my homepage layerslideshow is not scaling properly.
When viewing the site on computer, there is a lot of white space on left and right side of the content.
How do I make the content fill the area? Keeping to 15px of space on both sides?
http://hopereignsarabians.com/v2/
Hi Pappy
Presuming I understand you correctly, you wish to have a fluid width rather than a set width for the content area of your site? To do so try adding the following to the Custom CSS field of your templates parameters...
.wrapper960, .backgrounds .content_background {
width: 95%;
On what screensize/device are you having an issue with your slideshow?
Fluid code is perfect. Thank you.
I'm viewing on ipad/landscape.
I added this, but it still doesn't seem quite right:
.layerslideshow .img-fill img {
max-width: 100%;
min-height: auto;
I've tried a 3 sizes...what is the correct/optimum size for the layerslideshow images?
Currently they are 1080 x 810
Hi Pappy
For our template demo slideshow images used are 1500px * 1000px.
Could I ask you to detail the issues with the slideshow? Are images been cropped? Are image been displayed with an incorrect width/height ratio?
Yes, it's not scaling properly. Incorrect width/height ratio on Ipad
I've resized all to 1080 x 720, no difference.
Going to remove the CSS I added and try more square images.
I like the full bleed effect, but may switch to a fixed sized layer slider plugin if I can't get it to work...unless this one will do that.
Hi Pappy
If you are unable to find a solution may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
