1. deaksie
  4. Wednesday, 21 September 2022
Last issue (I think) with the J4 upgrade - I've found that I don't havearticle titles since the upgrade.
I have searched the forum but can't find anything.
If you look at this page here for example https://lithify.co.uk/services/incident there should be a title which says "Incident Response" between the picture and the body of the text.
If you could give me any pointers I'd be grateful
Many thanks
Liz
Hi Liz
I notice in the CSS the following code.
#main .page-header {
display: none;
You could add the code to the CSS area of the template and change to
display: block;
Firstly do you have Article Title set to show either in the article global options or in the menu. I have attached 2 screenshots for you.
Your site is currently using the H2 for the title. For the main title and SEO purposes it would be better if it was H1. Just a little tip. ;)
Dave
Attachments (3)
Hi Dave
Thanks for this I checked all the screenshots against the live site, and mine all matched yours (nothing had changed from before the upgrade), but I added the CSS and everything now works.
Regarding H2/H1 - you're right - they should be H1, but I've never got around to figuring out how to change it, do you have any recommendations please?
Thanks for your help so far, very much appreciated
Liz
Hi Liz
OK, this will need to be carried out in 2 places.
In the article options toggle off Show Title.
In menu options toggle on Show Page Heading
This will give you the H1 tag. The title shown will be the Menu Title. If the article title is different then go to Page Display Tab and add the article title there.
On the last attachment (dev site) you will see Terms which is the H1 linked to the menu title. The H2 Consent is the article title as I have left both options toggled to Show.
Hope that helps
Dave
Attachments (4)
OK thank you, I'll give it a go, very much appreciated
L
Thank you for bringing this to our attention. We have just added this fix to the latest update of the Skylar template.
