1. peterspie
  3. Monday, 18 June 2012
Hello, I am using the oxygen template, and would like to add a separator (a thin line) to the articles, show in blog layout. I have added to the template the following css-code:
.item-separator {
border-bottom: 1px solid #CABFB1;
display: block;
margin: 10px 0;
width: 100%;
and this adds a thin line, but it also adds a thin line on the front-page. I don't want this. Is it possible to have it only in the blog-layout?
I just realised that this has probably nothing to do with this oxygen template, but is a general joomla issue. Maybe someone has the right clue?
Regards, Peter
link to the blog layout
link to the front page
Hi peterspie
Try replacing your CSS with the following to narrow it down to your blog..
[code type=css].blog .item-separator {
display: block;
margin: 10px 0;
width: 100%;
}[/code]
Hello Ciarán,
it is working!. Thank you so much. I have searched so long on the internet, and you solved it so fast.
Thanks again.
Regards, Peter
I'm new here and hope to get some help.
i'm having a similar problem.
I do have a category blog where I want to add a thin line between articles.
I added the code above to my template css. I was wondering where to add the link to this piece of css code to make a line visble.
Thanks for your help
Edwin
  3. # 3
Hi Edwin
Would you have a URL to an example of where you wish to add the item seperator?
  3. # 4
Just tried to add this css code to the Lighttouches template, but it doesn't work. Added it last in the template.css
Here: link
  3. # 5
Trying to create the same with template Enlighten to get a line between the articles in Category Blog layout. I tried both of the above css codes and it didn't work.
The website is ..[deleted]
Many thanks,
Euan
  3. # 6
Hi Eaun
Try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
.items-leading, .items-row {
border-bottom: 4px solid #aaa;
margin-bottom: 20px;
  3. # 7
Perfect!
Thanks, as always, great support!
Best wishes,
Euan
(If it's okay I'm now going to remove the link from the previous post as this is a personal family/friends website only)
  3. # 8
Thanks. Also it helped my problem
  3. # 9
Which code should I use for Enterprise? None of the above is working, only in the bottom of the blog layout. Need separator between each articles in blog layout.
  3. # 10
Please include a URL to an example of your articles?
  3. # 11
I can't at the moment. Local host.
  3. # 12
How do I add this feature to Kinvara? I am using the blog layout with unlimited leading articles. None of the above works.
  3. # 13
To add a line between each leading items on the Kinvara template you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)...
.items-leading > div {
border-bottom: 1px solid rgba(0, 0, 0, 0.1);
  3. # 14
THANK YOU :D :D :D
  3. # 15
