how to add the edges (eg rounded) in my articles and modules?
my site : (template alexis)
http://gef-molsheim.org/index.php
as exemple of nice articles border :
http://www.potions-et-chaudron.com/
- DiabloV
- Wednesday, 16 December 2015
This would vary slightly depending on the module position you wish to effect however an example that would effect your contenttop module positions would look something like the following (Custom CSS - edit to taste)...
.contenttop .module_surround {
border-radius: 6px;
box-shadow: 0 0 4px rgba(0, 0, 0, 0.5) inset;
Try also adding the following...
.maincontent {
border-radius: 6px;
thanks for the idea...
but now I have all the same empty areas that are impacted, and that's ugly.
You could try adding a margin to your article area. Something like the following which will bring your borders in line..
.maincontent {
margin: 0 20px;
Thanks, but....
not working. I always have this box blank.
actually my problem is this empty frame. where is he from ?
This is the article/component area of your template. To hide may I suggest the following article.. http://www.joomla51.com/tutorials/item/hiding-the-component-article-area-on-a-page
- # 9
There may be no solution for what you require however I am presuming you want this above square removed on just this page? If so you will need to create a separate template style specifically for this page to which you will add the suggest CSS in the article. For details on creating multiple template styles please check out the following tutorial... http://www.joomla51.com/tutorials/item/creating-multiple-template-styles
- # 11
