1. kevinfrehill
  3. Wednesday, 05 October 2016
Hi I am having a problem with the Ashley template. I have a blog layout set up. The image for the articles are set to float left. It only seems to do this on the first article displayed and the other ones the text goes below the picture. I haven't had this issue before. I've attached an image to show you what I mean.
Regards,
Kevin
Hi Kevin
It was causing me a few problems with leading articles also (even though it wasn't on other templates set up the same) so I just started putting the pictures into the articles themselves. I have another question though. On the template scarlett (which I have also purchased) you have a blue line break after each blog post after the read more button. Is it possible to incorporate this into the Ashley template?
Hi Kevin
.blog .items-row {
border-bottom: 1px solid rgba(0, 0, 0, 0.1);
margin-bottom: 40px;
Sorry it didn't do anything.
Kevin
Hi Kevin
Would you have a URL to an example of your Ashley blog?
Could you try using the following instead (edit to taste)...
.blog .items-row {
border-bottom: 1px solid #1e73be;
