Hi.
I am using your PianoForte template for this site (http://faroexpo.konsult.fo/), where I have a the top main menu with sup-menus as the dropdown.
Would like to ask if it's possible to have an arrow icon pointing down to the right of each Menu that has a dropdown?
See attached Screenshot example.
This so, that it will be easier for users to see that there is a dropdown from those menus.
Tried to just add a "Link Image" to the menu "Partenariat" from it's menu parameters, but it does by default display above the menu. Haven't really figured out the CSS how to have it be right of the menu title. The menu width should best also increase a little with this arrow.
But by through this method you will also have to manually add a link image, everytime you add a menu with a dropdown.
A better alternative would be - if possible - to add a function to the template, so that 'IF' a Menu has sup-menus (dropdown) a arrow icon will display to the right of the menu title automatically.
