There seem to be some issues with installing the template on Joomla version3.0.2
This server is with Rochenhost
Main problems
1.mod_j51imagelinkhover does not install and gives an error message
2.Slideshow installs but has fatal error
3.CSS validation 868 Errors and 511 Warnings
4.HTML Markup Validation 19 Errors
5.Chrome inspect element 2 Errors
6.templates/j51_arkadia/php/scripts.php still has an extra " at the end of the file.
Please advise if these can be corrected in the very near future.
Barbara
Here are my notes with error messages:
Download arkadia and unzip.
Login to joomla admin
Click Extensions and select extension manager
Click Choose file
Select j51_arkadia.zip
Click upload and install
Success
Repeat for
mod_j51imagelinkhover.zip
Failed to install with error
JInstaller: :Install: File does not exist /home/public_html/arkadia/tmp/install_50b9fb37396c9/mod_j51imagelinkhover/images
I Corrected mod_j51imagelinkhover.zip changed img to images.
Success
Repeat for mod_j51thumbsgallery.zip
Success
Repeat for mod_slideshow.zip
Success
Go to blah.com/ in Google Chrome
Inspect element
Line 11 "Uncaught SyntaxError: Unexpected token <"
Line 149 "Uncaught ReferenceError: MenuMatic is not defined"
templates/j51_arkadia/php/scripts.php is still incorrect and has " at the end after script.
Go to Module Manager and Publish;
Slideshow.
Thumbs Gallery
Image Link Hover
Update slideshow with images and add to all pages.
Errors
Warning: require_once(/home/public_html/arkadia/modules/mod_AutsonSlideShowDShelper.php) [function.require-once]: failed to open stream: No such file or directory in /home/public_html/arkadia/modules/mod_AutsonSlideShow/mod_AutsonSlideShow.php on line 14
Fatal error: require_once() [function.require]: Failed opening required '/home/public_html/arkadia/modules/mod_AutsonSlideShowDShelper.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/public_html/arkadia/modules/mod_AutsonSlideShow/mod_AutsonSlideShow.php on line 14
Unpublish Slideshow
Update Thumbs gallery and publish to all pages.
Success
Update Image link Hover with filler1, 2 , 3 and 4 publish on home page.
Success
CSS Validation
http://goo.gl/ezr8L
Shows 868 Errors and 511 Warnings
http://goo.gl/x1452
Shows 19 errors
