1. ziggy
  4. Tuesday, 12 March 2013
I'm having a problem with a menu in the sidecol-a position:
I have a three level menu which I would like to show like this when expanded:
> Level 1
..> Level 2
....> Level 3
(dots are spaces)
But it shows:
> Level 1
.> Level 2
.> Level 3
So, 2 and 3 ar in the same level, besides, there is no hover color change in those levels, therefore it doesn't look nice when selecting options.
Any way to fix this?
Thanks!
Ok, that's all
Thanks a lot Ciaran for your help.
You can edit the color of your sub items with the following CSS which you can also add to the Custom CSS field of your templates parameters..
[code type=css].module ul.menu li li a, .module_menu ul.menu li li a {
color: #366C9A !important;
}[/code]
For your sub sub menu items add the following..
[code type=css].module ul.menu li li li a, .module_menu ul.menu li li li a {
}[/code]
Where #366C9A is your new sub item color.
Thanks Ciaran!
That worked perfectly!
The only problem left is that color does not change in level 2 or 3 when mouse hovering.
Is there a solution for this?
Thanks again!
Thank you Norberto
To better style your child items try adding the following to the Custom CSS field of your templates parameters..
[code type=css].module ul.menu li li, .module_menu ul.menu li li {
margin-left: 12px;
}[/code]
The site is not online yet, but I uploaded an image capture of the menu:
http://img209.imageshack.us/img209/159/menufj.jpg
First item is level 1
Second is level 2
third and fourth are level 3
Even they are multiline options, if I make them one line only the result is the same.
Hi Norberto
Would you have a URL to an example of your menu?
