1. kpomilla
  3. Wednesday, 12 February 2014
I am having problems with a script font appearing with certain components I've installed. At first I thought it is the component placing the font, but it seems to be happening with different components I install. It always seems like a header that has a script font, and I'd like to learn how to change it.
See attached pic for example of the font issue.
Thank you.
Your extenion appears to be using H2 tags which is the same as the article titles in Joomla. To define styling specific for this extension for the H2 tag try adding the following to the Custom CSS field of your templates parameters (edit to taste)..
#xmap h2 {
    font-family: Arial;
    font-size: 22px !important;
    padding: 10px 0;
