1. Internetional
  3. Friday, 20 November 2015
Hello Ciarán,
I couldn't figure out how to put objects in template "Arkadia" position footer1 side by side. They apear one over the other:
http://joomla.noobinator.de/
Can you tell me how to code this?
Thanks and regards,
Marek
Hi Ciarán,
I found an other solution. I just put the html code of the the objects on after the other into a html-modul and it is being displayed in a row:
Thanks and regards,
Marek
Hi Marek
The footer-1 module is a single column module, full width position by default. Regardless try adding the following to the Custom CSS field of your templates parameters where 300px is the width of your modules (edit to taste)...
#footer-1 .module {
float: left;
max-width: 300px;
