What I want to do is create multiple copies of the module so that the main content of a page is composed entirely of image links that go to separate articles. I want those image links to default to a grid layout determined by the body width.
So, for example, right now I can create 6 image link modules, but if I assign them to the custom position "embed," they simply appear vertically, all in one straight line down the page. I can get the grid layout (2 columns) but only by assigning every other module to the content position "contenttop-a" and "contenttop-b" respectively and that's not going to work well.
I've attached screencaps. The first (exa.jpg) is how the modules look with a custom position. The second is how they look using alternating a and b positions. What I want is to use a single custom position (i.e. "embed"
 and have all modules with that position name appear side by side, breaking to a new line when they run out of space. So for the current layout, two modules could fit on one line. If I got rid of the side column, 3-4 links could probably fit and it should automatically adjust to fill the space.
 and have all modules with that position name appear side by side, breaking to a new line when they run out of space. So for the current layout, two modules could fit on one line. If I got rid of the side column, 3-4 links could probably fit and it should automatically adjust to fill the space.Where in the code can I adjust these settings and get the needed effect? Thanks!
