1. jv
  3. Friday, 17 January 2014
I don't know when this started, but the footer has shifted its horizontal alignment to the right by 50 px or so. Or perhaps the main body has shifted to the left. I've attached a pic of the problem. You can also see it at http://www.rapmag.com.
Thanks!
jv
Hi JV
Near the top of your templates base.php (../templates/j51_arkadia/php/layouts/base.php) could you try replacing the following...
<div id="container_base" class="container"><div class="wrapper960">
with...
<div id="container_base" class="j51contain"><div class="wrapper960">
Yes, that worked for the Custom Footer module. The very bottom module is still out of alignment. Pic attached.
Thanks!
jv
Hi JV
Could you also try replacing the following at the very end of the same file...
<div id="container_copyright" class="container"><div class="wrapper960">
with...
<div id="container_copyright" class="j51contain"><div class="wrapper960">
Worked like a charm, Ciaran. You're the best!
Thanks!
jv
