Good morning, i just installed Arana's Template, and trying it's features.... when i'm put more than one o Layer Slideshow module in the same page, the Slide Title text and the Slide caption appear only for one of them, and not on the others added. what's wrong? can you help me?
thanks
Could I ask you to allow us access to your Extensions Manager so we can update your LayerSlideshow module. Alternatively, try installing the attached update.
				finally i fix it!
the problem is if any slide show module have the Overlap property on! if i set it only on the first one it works fine!
bye
bye
.layerslideshow .info {
    opacity: 1;
}Ciaran
Sorry to say we have no record of your email. Could I ask you to resend and include a URL to this post in your email for our reference. Once sent, ping this post so we can expect it and get back to you if we still have not received it.
 - # 9
				Hello! I just tried to install the attached update but it doesn't work
text only appears on one layer at a time
http://www.rotamobili.com/index.php/test
 - # 10
				one more information, may be can helpful...
if i put "show title" ON, on the two different layers, the title appear only on one of this but, show the wrong title, as if it reversed between the two
I left an image to explain better
thank you
thank you
 - # 11
