I re-did the migration, the same issues encountered. I attahced the error logs as follows (perhaps it may help):
[21-Jan-2020 14:39:19 America/Chicago] PHP Warning: require_once(/home1/kairos/public_html/
http://kairos.sg/includes/defines.php): failed to open stream: No such file or directory in /home1/kairos/public_html/
http://kairos.sg/index.php on line 37
[21-Jan-2020 14:39:19 America/Chicago] PHP Fatal error: require_once(): Failed opening required '/home1/kairos/public_html/
http://kairos.sg/includes/defines.php' (include_path='.:/opt/php71/lib/php') in /home1/kairos/public_html/
[21-Jan-2020 14:46:32 America/Chicago] PHP Warning: require_once(/home1/kairos/public_html/
[21-Jan-2020 14:46:32 America/Chicago] PHP Fatal error: require_once(): Failed opening required '/home1/kairos/public_html/
[21-Jan-2020 14:57:04 America/Chicago] PHP Warning: require_once(/home1/kairos/public_html/
[21-Jan-2020 14:57:04 America/Chicago] PHP Fatal error: require_once(): Failed opening required '/home1/kairos/public_html/
[21-Jan-2020 15:11:41 America/Chicago] PHP Warning: require_once(/home1/kairos/public_html/
[21-Jan-2020 15:11:41 America/Chicago] PHP Fatal error: require_once(): Failed opening required '/home1/kairos/public_html/
[21-Jan-2020 15:14:15 America/Chicago] PHP Warning: require_once(/home1/kairos/public_html/
[21-Jan-2020 15:14:15 America/Chicago] PHP Fatal error: require_once(): Failed opening required '/home1/kairos/public_html/
[21-Jan-2020 15:14:16 America/Chicago] PHP Warning: require_once(/home1/kairos/public_html/
[21-Jan-2020 15:14:16 America/Chicago] PHP Fatal error: require_once(): Failed opening required '/home1/kairos/public_html/
[21-Jan-2020 15:29:31 America/Chicago] PHP Fatal error: Uncaught RuntimeException: Library path /libraries/src cannot be found. in /home1/kairos/public_html/
http://kairos.sg/libraries/loader.php:438
Stack trace:
#0 /home1/kairos/public_html/
http://kairos.sg/libraries/cms.php(33): JLoader::registerNamespace('Joomla\\CMS', '/libraries/src', false, false, 'psr4')
#1 /home1/kairos/public_html/
http://kairos.sg/includes/framework.php(18): require_once('/home1/kairos/p...')
#2 /home1/kairos/public_html/
http://kairos.sg/index.php(40): require_once('/home1/kairos/p...')
#3 {main}
thrown in /home1/kairos/public_html/
http://kairos.sg/libraries/loader.php on line 438
[21-Jan-2020 15:46:46 America/Chicago] PHP Warning: require(/home1/kairos/public_html/
http://kairos.sg/libraries/vendor/composer/../joomla/string/src/phputf8/utf8.php): failed to open stream: No such file or directory in /home1/kairos/public_html/
http://kairos.sg/libraries/vendor/composer/autoload_real.php on line 66
[21-Jan-2020 15:46:46 America/Chicago] PHP Fatal error: require(): Failed opening required '/home1/kairos/public_html/
http://kairos.sg/libraries/vendor/composer/../joomla/string/src/phputf8/utf8.php' (include_path='.:/opt/php71/lib/php') in /home1/kairos/public_html/
[21-Jan-2020 15:46:47 America/Chicago] PHP Warning: require(/home1/kairos/public_html/
[21-Jan-2020 15:46:48 America/Chicago] PHP Warning: require(/home1/kairos/public_html/
[21-Jan-2020 15:46:48 America/Chicago] PHP Fatal error: require(): Failed opening required '/home1/kairos/public_html/
[21-Jan-2020 16:48:32 America/Chicago] PHP Warning: session_start(): Failed to read session data: user (path: /tmp) in /home1/kairos/public_html/
http://kairos.sg/libraries/joomla/session/handler/native.php on line 260
[21-Jan-2020 16:48:33 America/Chicago] PHP Warning: session_start(): Failed to read session data: user (path: /tmp) in /home1/kairos/public_html/
