1. pat02
  4. Thursday, 13 June 2019
I have created a form that contains date fields.
Clicking into such a field shows the date picker (mini calendar) for a very quick time then is disappears. I have no chance to select a date.
If I switch to Protostar template the date fields work fine.
Can I send you URL and Login so you can have a look at it?
Thanks a lot.
Patrick
Hi Patrick
Your forms component does not appear to be compatible with the animate.css (https://daneden.github.io/animate.css/). I have disabled this option in the templates General -> Misc tab of your template settings and your date field appears to be now working without issue.
Thanks a lot.
I did pass this to the developer of Chronoforms
https://www.chronoengine.com/forums/posts/t107378
Patrick
