MENU
  1. tcm1003
  4. Monday, 18 July 2022
I purchased multiple templates and everyone comes with a slideshow module. Are they different or specifically adapted to their respective template or are they interchangeable?
If you fix a bug or add a feature, does this effect every module of every template or just one?
(And I need more then "bug" and "issue" as type of question... feature request would be nice :-D)
The LayerSlideshow module is a singular extension and the same for all templates however where a difference may arise is when a template override is created. You will find these listed in the template html folder (../templates/[YourTemplate]/html). Also in some instances, the template would have CSS that will affect the slideshow module so the slideshow may be styled differently depending on the template it is installed to.
