1. salinger
  4. Thursday, 22 September 2022
please have a look at https://www.dr-locker.at/index.php/de/
the module with the text "Rezeptanfrage" shall be animated on scroll. I have active the animate.css in the template section, but as soon as I write "animate fadeIn" in the module class suffix, the module disappears.
Right now I have deleted the animate part, because its necessary to show up. Any idea what this might cause the problem?
Thanks, Marion
Have you tried adding it like this.
animate fadeIn delay-600
Also in the module class suffix you need to leave a space at the start, image attached of a setting I have used.
David
.animate {
visibility: visible;
Installing the latest download of your template appears to have resolved the issue.
THANKS SO MUCH!!!! :D :D :D
Hi David thanks for trying to help... unfortunately still it does not work. attached how I used the module class suffix , and screenshots of the front page. without the module class suffix you can see the module, and with it you don't :(
regards, Marion
Attachments (3)
Hi Marion
That's odd.
I did notice that you have the following deferred styles in the source code. I am not sure if this is the issue. If you have a plugin or something on the hosting account deferring scripts loading can you turn them off? It may not be that at all of course but just trying to eliminate the cause!
<noscript id="deferred-styles">
<link href="/templates/j51_layla/css/animate.min.css" rel="stylesheet">
<link href="/templates/j51_layla/css/fontawesome/fontawesome.min.css" rel="stylesheet">
<link href="/templates/j51_layla/css/fontawesome/v4-shims.min.css" rel="stylesheet">
<link href="/templates/j51_layla/css/fontawesome/brands.min.css" rel="stylesheet">
<link href="/templates/j51_layla/css/fontawesome/regular.min.css" rel="stylesheet">
<link href="/templates/j51_layla/css/fontawesome/solid.min.css" rel="stylesheet">
</noscript>
David
good morning David,
it's getting weirder ..
I did not install any plugins , maybe the company which took care for the SEO after me, I don't really know. I only found one unusual plugin which I sure did not install, but deactivating did not help.
I found this code you mentioned too, but then, after trying again to animate the module again, the code is gone. I can't find it anymore. But still the module animation is not working, still not visible.
thanks, Marion
Hi Marion
it is very weird indeed. I think Ciaran may need to login and take a look. Hopefully he will respond soon.
David
Thanks Ciaran, it is visible but the animation does not work...:o animate.css is activated... any ideas left? thanks so much!
