We are using the Caitlin template j3 and we have about a gazillion anchor links.Thanks to earlier code you gave me I got them to jump to the right places but I have another problem.
When jumping from one anchored link on the menu, to another anchored link on the menu sometimes the top menu doesn't appear as fixed to the top of the page the way it does when you scroll down a page.
As an example if you go from:
http://griffithrushd233.s16.cpsvr.com/about-us#oic
to
http://griffithrushd233.s16.cpsvr.com/life#gm
Or
to
http://griffithrushd233.s16.cpsvr.com/client-portal#sr
You might have to try it a few times to get the menu not not show.
When that happens the menu is still stuck to the very top of page.
Do you have any idea how to fix that?
Thanks so much,
Mike
