1. Ko3n
  3. Sunday, 10 March 2019
Hi Ciarán,
Do you know about any problems concerning AllVideos from JoomlaWoks and your J51 Carousel module?
Because the J51 Carousel module is not displayed when I place it on the same page as the AllVideos module. So both modules one same page do not work. The page shows only the video but not the J51 Carousel module :o
Can you test it? I tried it with the Chloe template.
Kindly,
Chris
p.s. A solution would be a own module with the following code:
<p><iframe src="/https://www.YourYouTubeEmbedLink.com" width="560" height="315" style="display: block; margin-left: auto; margin-right: auto;" frameborder="0" allowfullscreen="allowfullscreen"></iframe></p>
  1. https://extensions.joomla.org/extensions/extension/multimedia/multimedia-players/allvideos/
Hey Ciaran,
The problem was that I had an older version of Google Chrome :p :p
After update Chrome it works well. So everything fits now :D
Sorry for my mistake:(
Chris
Hi Chris
have you since been able to resolve this issue? Checking in Chrome it appears all images are now the same size.
It's alright I solved it with the code above. And it looks much better on the phone.
But another thing. Works The Thumbs Gallery Module with Google Chrome?
I made a simple page with The Thumbs Gallery Module but the images are not displayed correctly with Chrome.
Take a look at the picture. The pictures are displayed in different sizes :D
http://www.optimalpraesent.at/images/fail/fail.png
But it works fine with IE, Opera and Firefox :o
How can that be?
If I delete the last four pictures, it will also be displayed well in Chrome. Maybe I'll do that if you do not have a better idea :)
Kindly,
Chris
  1. http://www.optimalpraesent.at/index.php/sonderanfertigung
Would you have a URL to an example of the issue?
