1. belex24
  4. Tuesday, 25 September 2018
Hi there,
I changed in the file jquery.slicknav.js allowParentLinks: true, the menu type is set to SlickNav. But it just opens the sub items instead of switching to the appropriate page.
Please help. Thank you!
Tina
  1. http://www.newhouse.at/triestingtal/
May I suggest sending temporary access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
Ok, it's on its way. Thank you!
Thank you Tina
thank you so much! Works like charme! Tina
Hello, I have the same problem with SlickNav.
My template is J51_Colette for Joomla 4.
I have in the main menu for example: Prices - and two other submenus.
When I open the website on my cellphone I can see the menu:
the first item (prices) doesn't open, the two submenus work fine.
I have modified in the javascript the line as follows:
but it does not work as desired.
What can I do?
I ask for help
Thanks from Austria
Wilfried
Hi Wilfried
done!
I'm having the same issues with various templates. What can I do?
Thanks.
Hi amo
I just sent you a login and pass... thanks...
