1. bibbp
  4. Tuesday, 05 March 2019
Hi ciaran,
I am using SlickNav in the responsive options, and have changed jquery.slicknav.js to set AllowParentLinks to 'true', I am still not getting the the root mane item to work. Is there something else I need to do?
thanks
Peter
  1. https://www.knoleparkgolfshop.co.uk/
Hi Jan
I am not sure if I understand you correctly. Could you please elaborate for me.
Could I use the same für mobile slideout menu or is it possible an other methode?
TX
Jan
Perfect!
Many thanks Ciaran, as always.
Peter
Hi Peter
In your templates scripts.php (../templates/[YourTemplate/inc/scripts.php) try replacing both instances of the following (line 11 & 17)...
jquery.slicknav.min.js
With..
jquery.slicknav.js
Does this help?
