1. revolion
  4. Tuesday, 12 June 2018
I'm working with Kaylee template. I adjusted the js to read as allowParentLinks: true, but mobile isn't responding. Is the option somewhere else in the code to turn on enable parent links?
Thanks,
The switch was set to slide out and not slicknav. Got it fixed now, thank you for the reply!!!:D
Can you confirm that you are using the 'SlickNav' mobile menu type (Responsive Options tab)? The option to have clickable parent items is only available with this menu type.
