1. webbie
  4. Thursday, 30 June 2016
i use your caitlin template and wanted to put some pictures in it, but always the pictures are very big, bigger than i made them - also i want the logo not seeen, but if i disable it, evrything is more bad than before.
Which size must the pictures have to fit in the slideshow from the template?
And how can i disable the logo?
You can find my site here: http://ralphbosse.test.bz.it/
Hi Webbie
To resolve try adding the following to the Custom CSS field of your templates parameters...
.vegas-slide-inner {
background-size: 100% auto !important;
To hide the logo you can also add the following....
.logo {
display: none;
And just to give your header a physical height without the logo, also add the following...
#header {
height: 91px;
Yes - great solution! Thanks a lot!
