1. Burnardo
  3. Monday, 04 March 2019
Just did a fresh install of the Everly template.
Where can I change the values for parallax backgrounds.
Some module background images are shown with parallax effect. Where can I adjust the amount for this effect?
Ooops,
Also here, I found the answer by looking a bit closer.
The bottompart of the index.php shows this script part:
<script>
jarallax(document.querySelectorAll('.jarallax'), {
speed: 0.5,
disableParallax: /iPad|iPhone|iPod|Android/,
disableVideo: /iPad|iPhone|iPod|Android/
</script>
The definition for jarallax is set here and used and at some module positions.
The setting of speed needs to be between 0 and 1.
(Hopefully this will also help others...)
Thank you for sharing your solution!
