I am using your demo install of the Everly Template to develop a website located at the temporary domain name of http://tempdomain45.site .
Everything seems to be working correctly but the homepage slideshow which I am using only one slide is being cut off so that I am unable to view the entire image which is also cutting off some of the text on that slide.
I would appreciate you looking into this issue and let me know if there is some coding you can provide that would improve the mobile view on this website.
This is my first time to use the Everly template but I really like the design elements and hope you can correct this one portion of the web design.
Thank you for much. Your technical assistance has always been wonderful!
I use only Joomla51 templates in my web design business.
Thanks in advance.
James
