1. webneus
  4. Thursday, 06 June 2024
I want to add the HR so that there is a better separation between the news articles. The HR is now very narrow and I want to make it thicker and longer. I saw this tip but it doesn't work for me.
hr {
height: 0;
max-width: 100%;
Can you help further?
Greetz Maikel
  1. https://emm.webneus.nl/index.php/nieuws
I'm not ciaran but maybe my solution will help you too.
You have to copy the code into your template styles in the settings in the tab: "CUSTOM CODE"...
hr {
max-width: 90%;
margin: 15px auto 20px;
border-top: 10px;
You can then adjust the numerical values ​​of the code as you wish
Hi Eumel7,
Unfortunately this doesn't work for me. Placed it in the Custom CSS
But thanks!
Maikel
Hi Maikel
hr:not([size]) {
border-top-width: 5px;
max-width: 300px;
Edit to taste
Still not working my friend.
Maikel
I am not seeing the suggested CSS in your source code. Do you have multiple template styles created? If so, could you try adding the CSS to each of the styles.
1 style with code in CSS see attachment,
Maikel
Just a try. When I look at your picture, could it be that the code above the rule is missing the final "}" ??
Hi Eumel,
Sharpe! But still not working.
Maikel
Too bad.
Apart from the fact that you inserted the code in the wrong template style, I can't think of anything else...
Sorry
hr:not([size]) {
height: 3px;
works for me
Could you try placing the CSS at the start of the field rather than at the end? If there is any errors in CSS, CSS after the error will not get applied.
Still not working,:(
Maikel
Can you paste your entire CSS code here?
try this
hr {
height: 1px;
max-width: 300px;
border-top: 5px solid var(--primary);
Hi FrancW,
Thanks my friend, problem solved!
Maikel
