Is it possible to embed an image to the top-1 background? The Renovate template manager styling tab allows you to edit the Top-1 Modules background color but adding a permanent image is what I am looking for. I have attached an SS of the website and what image I want to add and placement.
If it cant be centered is it possible just to make it run infinity from left to right so it will be full all the way across depending on what size monitor you are using as the background colors do?
