1. Dr Drew
  4. Monday, 20 March 2023
Hell,
I have followed the tutorial for 'Adding a Font Awesome icon to a menu item' and cannot get the Emainei template to display the same (see screenshot) as a simple search icon. The placement is visible but the icon is absent.
What do you suggest, please?
Kind regards
Drew
  1. https://unusualrisks.com.au/
you are using the 4.7 font awesome, it needs to be 5.0 thats what joomla is using. Try fas fa-search
Your horizontal menu is barely visible, when the background image is rather light. You might add some custom css like this:
#hornav-nav {
	background: darkorange;
    border-radius: 10px;
Perfect fix, thankyou.
