1. smithjd44
  4. Wednesday, 16 July 2014
I am trying to add a smaller logo for mobile devices in the Habitat template.
My logo extends across the header but when viewed on mobile devices it is way too large.
I have tried the CSS code recommend in the Forums but without success.
The link to my website is http://192.185.157.211/~future/.
Thanks for any assistance you can provide me!
James
I have the exact same situation for this template. I've also tried all of the recommended code additions suggested elsewhere in the forum, also without success. The link to my website is: http://www.dunschiropractic.com.au/index.php
#header.block_holder {padding: 0 10px;}
.logo_container, h1.logo, h1.logo a {height: auto;}
.logo a {top:0; left: 0;}
.logo img {
left: 0 !important;
margin-left: 0 !important;
max-width: 100% !important;
This CSS should work for both logos.
Worked perfectly!
Thank you so much!
James
Thanks also, I added the above and with some additional changes to the css, was able to work a solution.
