1. OldRock
  3. Monday, 28 May 2018
Can you tell me if the Stockholm template does a template override for the AcyMailing view?
I have a problem with the AcyMailing front end list management giving a 404 error. The response from Acyba was as follows:
please make sure that you don't have AcyMailing template override for the AcyMailing view in the Joomla template which you are using on your website. If you do have, either disable it or recode it to work with the new version of AcyMailing
Regards,
Igor - Acyba help desk team
I can't find any mention of AcyMailing in the template parameters.
Thanks,
Graeme
Hi Graeme
By default our templates do not include an override for the AcyMailing extension. You can check this by navigating to the html folder of your template (../templates/[YourTemplate/html) and ensure there is no folder name consisting of 'acymailing'. If there is (your may have created one via the Joomla admin) you can disable it by simply renaming it (eg. add a '1' to the end of the folder name).
Thanks Ciarán. I checked and there are no folders for AcyMailing in the template HTML folder.
Thanks for your help.
Graeme
