1. GF
  4. Tuesday, 26 March 2019
Is there a way to use the 7-stroke icons in a menu-item or can I only use FA?
Regards,
Geert
My apologies.
By default, the template only has an option to load the Font Awesome. To also include the Stroke 7 icon set you can add the following to the Custom Head Code field of your templates which will load the icon set from a CDN...
https://www.jsdelivr.com/package/npm/pixeden-stroke-7-icon?tab=collection
In the above page click the HTML output option and copy the link tag
Thankx Ciaran. It works but it also changes the font that I use for the menu-item...
