1. HanvdG
  3. Friday, 20 March 2015
Hi !
Since some time I have a message on the header in my template Metropolis. I can't find the place where to remove or disable this.
It's on http://www.hanvandegraaf.nl.
Thanks for your help.
Han
Hi Han
This appears to be a menu item in your top menu which has wrapped to a second line. A CSS solution would be to add the following to the Custom CSS field of your templates parameters...
.item-825 {
display: none;
Or of course you can simply disable it within your menu :)
Thanks Ciarán, That solved my problem !!
