1. mentil
  4. Tuesday, 24 January 2017
hello community,
i have installed serenity. i have 2 templates - one for the homepage - one for all others.
i want the header images only in the mainpage - not on the other pages.
See attachments - but it does not work.
Any Hints ?
Thank you.
Disabling the 'JCK Modal' plugin has resolved the issue which appears to be effecting your template menu assignment.
I would suggest setting the template style for all menu items except the homepage to your default template style. Then you just need to set the menu assignment for your homepage template style.
hello C.,
this is ecactly what i did. I just does not work.
will you have a look please?
thank you
You are the best. Thank you. I turned it on by accident.
