1. omik
  3. Saturday, 25 March 2023
Hello Ciaran
I have 2 questions about copyright parameters on Chloe template
1- Is there a way to change the copyright text from Upercase to lowercase or/and Title case?
2- Is it possible to add a second and a third line to the copyright text, so it will look like this for example:
Copyright © 2023 mysite.com All Rights Reserved
All photos on this website are copyrighted material.
No photos may be used for any purpose
Thank you in advance.
Omik
Hey Omik,
Regarding your first question. Try adding the following to the Custom CSS field of your templates parameters.
.copyright {
text-transform: lowercase;
Regarding your second question. The copyright field accept HTML so you can use <br>.
Copyright © 2023 mysite.com. All Rights Reserved. <br> All photos on this website are copyrighted material. <br> No photos may be used for any purpose.
Just check my screenshots.
Kindly,
Chris
Hello Ciaran
Thank you for your answer but unfortunately the code you provided didn't help. The copyright text is still in UPERCASSE.
As you instructed, I have added below code to the Custom CSS field, but it didn't work.
.copyright {
Regards,
Omik
Hi Omik
Would you have a URL to an example of your copyright text?
Hi Omik
you might try
.copyright p {
text-transform: none;
Rolf
Hi Rolf
Thank you so much for your kind answer, it worked.:)
All the best,
Omik
